Disc brake making loud noise.
Hello. I was changing the disc brake oil. And it was my first time. Split on the disk. And after 1 day it's making loud noise. I should clean it with disk brake cleaner? Or with wet towel?
@munkhorgil18434 use a rag and water to clean off any gross contamination. Then use some +95% isopropyl alcohol for a final clean. Again, use a clean rag for that and not a paper towel. Yes, you can also use commercially available brake cleaner. Make sure you take care of the pads as well. Use some #200grit paper to scuff them up and get rid of some of the debris on those pads.
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 171
