Released March 2019, identified by model number SM-A305FZRFINS
Why my phone is not connecting to my pc
I connected from my new usb cable to pc to mobile to transfer files from mobile to computer but phone didn't connecting when i used my old usb cable it was connected why it wasn't connecting to my computer from new usb cabe new was charging but not connecting?🥸
Some cables are not sync compatible. If the cable is a generic cable there is a good chance that could be the case.
The new USB cable likely doesn’t support data transfer. Some USB cables are designed for charging only and lack the wiring needed to transfer data between devices. Since the new cable charges your phone but doesn’t allow file transfer, it’s probably a “charging-only” cable.
To fix this, use a USB cable labeled for data transfer (often called a “sync” or “data” cable) or stick with your old cable, which works for both charging and data. Look for USB cables that specify "data" or "sync" in the product description if you need to buy another one.
Vedang Upadhyaya crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 133
