This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
The space to insert a disk no longer works
The space to insert your disk no longer works
Check in the cartridge reader to see if anything is bent or if it’s dirty. Clean it with isopropyl alcohol and try to get any pins that are bent back to their correct position. Also make sure your game’s contacts are clean. If that doesn’t work then you should probably check the board for corrosion and clean that up.
Hope that helps!
Tsepiso Koloko crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 56
