My laptop wifi have not working
How to fix the wifi on my laptop, it always disappear the wifi logo and cannot connect to internet
If the Wi-Fi on your Asus TUF Dash F15 keeps disappearing and you're unable to connect to the internet, there are several troubleshooting steps you can try:
1. Restart Your Laptop: Sometimes, a simple restart can resolve temporary issues. Restart your laptop and see if the Wi-Fi icon reappears.
2. Check Airplane Mode: Ensure that Airplane Mode is turned off. Airplane Mode disables all wireless connections, including Wi-Fi. You can find Airplane Mode in the Action Center or Settings on Windows.
3. Update Wi-Fi Drivers: Outdated or corrupt Wi-Fi drivers can cause connectivity issues. Go to the Device Manager, locate your Wi-Fi adapter, right-click it, and select "Update driver." Follow the prompts to update the driver.
4. Reset Network Settings: Resetting network settings can sometimes fix connectivity issues. Go to Settings > Network & Internet > Status > Network reset, and then follow the on-screen instructions.
5. Check Wi-Fi Settings: Make sure Wi-Fi is enabled in your laptop's settings. Go to Settings > Network & Internet > Wi-Fi and ensure it's turned on.
6. Check Wi-Fi Router: Ensure that your Wi-Fi router is working properly and that other devices can connect to it. If other devices are having trouble as well, the issue may be with the router.
7. Forget and Reconnect to Wi-Fi Network: Forget the Wi-Fi network you're trying to connect to and then reconnect. Go to Settings > Network & Internet > Wi-Fi, select the network, and then click "Forget." Afterward, reconnect to the network and enter the password if required.
8. Run Network Troubleshooter: Windows has a built-in network troubleshooter that can help diagnose and fix connectivity issues. Go to Settings > Update & Security > Troubleshoot, and then select "Internet Connections" under "Find and fix other problems."
9. Disable Power Saving for Wi-Fi Adapter: Sometimes, power-saving settings can interfere with Wi-Fi connectivity. Go to Device Manager, find your Wi-Fi adapter, right-click it, select "Properties," go to the "Power Management" tab, and uncheck "Allow the computer to turn off this device to save power."
10. Perform System Restore: If the issue started recently, you can try restoring your system to a previous point when Wi-Fi was working fine. Search for "System Restore" in the Start menu and follow the on-screen instructions.
If none of these solutions work, there may be a hardware issue with your laptop's Wi-Fi adapter, and you may need to contact Asus customer support or visit an authorized service center for further assistance.
crwdns2942667:0crwdne2942667:0 339
just to verify. the wifi logo disappears on the toolbar or just goes changes to another symbol showing it is disconnected?
crwdns2934271:0crwdnd2934271:0 Carlton Church crwdne2934271:0
