The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
Analog stuck pointing up ( missing part)
Hi . I tried replacing my left analog with a new one due a drift issue, but now it's stuck on pointing up . Tried to put the old one back and same issue. Is there anything to do to try save it or it need a new board now ? Thank you
update . i think i found the problem its a missing part i think i'll upload a picture of it
im not sure but i cant see anything else wrong with the bord
anyone knows if its possible to buy these ? thanks
ok , now the analog is fine but the RT button shows as pressed all the time .
could this missing part be causing it ?
Sorry for the late reply i didn't have time to take pictures.
Here is some pics , and yes i took the potentiometer off and it still pointing up
Hi! No problem! Not sure which component this is... I think it's easier to buy a broken motherboard or something and de-solder the component from there to solder it on yours. The component is not labeled as well, so it's hard to say at the moment... How are the traces? Are those OK?
Hi!
So the old one has the same issue now? Then most likely a solder pad/trace is damaged. Please make some photo's of the board and share it with us. With this we can determine what need to be done. Thanks!
crwdns2944067:08crwdne2944067:0:
Also , i know the potentiometer is not there , i tired without one and it still points up . The left/right works fine
@hamodizoabi Would you happen to have pictures of the board to ensure the traces within it aren't damaged?
I tried, not sure if you can actually see anything.
Would it be possible that I over heated the board ?
Overheating the board is possible. Because other components can be damaged with too much heat. Best thing to do is to post a picture (if possible). If a pad broke or trace, we should be able to see it. Thanks!
@dan0 i updated the pictures, is this board what you asking for or im missing something?
Hamodi zoabi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 253
