Lenovo Yoga Smart Tab tablet was launched on 5th September 2019. The tablet comes with a 10.10-inch touchscreen display offering a resolution of 1920x1200 pixels.
Network problem {emergency call only}
Network problem sometime it goes to zero, and after 2-3 hr it came back, tried everything Simcard, roaming, restart many times etc.
Well I will suggest you to do the following:
  1. Check if Your SIM Is Active and Turned On.
  2. Switch On and Off Airplane Mode.
  3. Change Your Network Type if you are using 2 sim's in your tab
  4. Manually Select Your Network Provider.
  5. Restart your tab.
  6. Check if Your SIM Is Inserted Correctly.
  7. Clear the SIM Toolkit App Cache and Data.
Utshah gupta crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 65
