Repair information for the Brother DCP-T300 printer. First available on Amazon in January of 2017. Model number: DCP-T300.
Why is my black ink not working?
Every time I print a document, the black ink is not working even though it has an ink inside the cartridge
Hi,
Have you check the ink is able to flow from the cartridge or the container to the printhead ?
If not you're printhead is clogged.
BR
Artefil
hi just go to menu settings deep cleaning press (menu + mono +menu) then press upward 7 and 6 and then press upward select black.
Go to the menu and maintenance and you will find a option for cleaning select black and use the strongest setting the printer will clean the ink head for you and it should work greatly after that
JARZELLE DE LEON crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 438
