Announced on 15 October 2023, identified by model number SM-A055M
Why I cant charge my Phone? Its not connected to charger
I cant charging my phone
@helianthus11954 this "Its not connected to charger" is confusing. It will not charge if it is not connected to a charger. I am sure that is not what you are wanting to say. Easiest answer in the case would be "Connect it to a charger" :-)
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
The A series has issues with the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards. I suggest that you start with a new battery if any of the above did not work. After that it's the charging board and flex cables.
If none of this works then teh issue will be with the charging circuitry on your motherboard. Let us know if anything worked. Otherwise we may have to get you to the board-level components.
Since iFixit does not yet have a specific guide for this, use something like this video to work on your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Helianthus Van Asteraceae crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 163
