The Xiaomi Mi 12 is a midrange smartphone, released in December, 2021. It features a 6.28" 120 Hz AMOLED display and runs on a Qualcomm SM8450 Snapdragon 8 Gen 1 chipset. Identified by model numbers 2201123G or 2201123C.
My fingerprint sensor is not working
Fingerprint sensor not working, The test said: CALI test result: false. What happened to it?
Have you replaced the display?
According to reddit you'll need to recalibrate the sensor if you have.
I'd also recommend cleaning the scanning area with a Microfiber cloth to ensure accurate reading.
"To access the calibration menu you need to:
Go to settings > About phone > All specs > repeatedly tap Kernel version until the calibration menu appears > tap the menu button in the top-right corner > Additional tools > 6. Fod fingerprint calibration.
Follow the steps on the screen. The first test is to hold a white cloth/paper over the fingerprint sensor. The second test is a black cloth/paper. The third test, just use your bare finger.
If it says "Test successful" at the end, the fingerprint sensor should be ready to use. If the test fails, try again. I read a forum post where someone had to try three or four times before it passed."
If recalibration doesn't fix the issue I'd recommend a visual inspection of the internal hardware.
by us Xiaomi 12X psyche - work well !!
THX
You are a legend brother, it worked for me! I can't thank you enough
Screen optical fingerprint malfunction usually occurs after replacing the screen assembly, fingerprint module, disassembling the device, or applying/removing a screen protector. You can try the following methods to resolve the issue:
Prepare a set of fingerprint calibration weights, which are rubber blocks with evenly engraved vertical lines, typically flesh-colored or black. Some people have successfully used a regular eraser wrapped with a rubber band as a substitute calibration weight.
Go to "Settings" -> "My device" -> "Detailed info and specs," and tap "Kernel version" repeatedly until you enter the CIT interface.
In the CIT interface, tap the three dots in the top-right corner, then click "Additional tools." click "Fod fingerprint calibration" and tap "start." Follow the on-screen instructions to complete the calibration using the calibration weight.
Note: Calibration will erase your previously registered fingerprint data.
If you are unable to complete the calibration successfully, you may need to replace the optical fingerprint sensor.
If you're using a third-party screen, the fingerprint functionality may not work, especially if the screen uses LCD technology instead of OLED. LCD does not support optical under-display fingerprint sensors.
I don't see it on settings
Law Nguyễn crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 73
crwdns2936753:030crwdne2936753:0 427
crwdns2942667:0crwdne2942667:0 4,120
