GoPro10可以开机,但是没有画面,又大佬知道怎么回事吗?
GoPro10 can be turned on, but there is no picture. Does anyone know what is going on?
Hi @laoliu1838,
Try taking a picture (I realize that you can't see what you're taking) and check if it is saved to the SD card in the camera.
Check if the picture saved on the card is OK or just a black image (download image from the card)
This is just to prove whether it is an image sensor (23MP ccd/cmos) problem or a motherboard problem.
hello jayeff.thank you for sharing the idea, which is very helpful for me to accurately locate the problem of the motherboard.
你好,jayeff。谢谢你提供的思路,让我很快定位到了问题。
Hi, I also encounter same problem, but it can work on the photo taking, and i can see the picture in my gopro app. But the video part is the same screen as the photo shown by the author
@map79mkv0wwwhpn
Just clarifying that taking/viewing individual pictures is OK but not videos, is this correct?
Also can you view any pictures in the LCD screen or not as I'm not sure if you can or can't?
Ye, video and time lapse all cannot, photo is just fine
Hi @map79mkv0wwwhpn
Seems more like a software problem than a hardware problem.
Try a factory reset and check if that resolves the problem.
Also check that the latest firmware is installed as well.
If still no good it may be a mainboard problem.
Hi, thanks for the answer, i had tried the above options.. i think is the mother board problem, the only way to fix it is through official repair, or if it is still worth the repair 🤣🤣🤣
@map79mkv0wwwhpn
A quick look online shows that a replacement board is about 75% the cost of a new Hero10 black camera and that is without the labour cost if you do it yourself.
You will have to decide which is the better option for you
@jayeff thank you so much for the advice man, will consider whether to throw this garbage or keep for the photo taking part LOL
crwdns2942667:0crwdne2942667:0 340
