@justinrobe87626 measure the voltage on your battery connector. measure without the computer being plugged in and then with it plugged in. The voltage will have to increase with the ac adapter connected. If it does not, then check the power supply as well as teh port controller etc. Make sure that you have power going to the charge circuit. This could be an issue with the charging circuitry. You can also check the amperage and see how many amps your computer pulls when you plug it in.
Your laptops motherboard should be a DAAY21AMB6D0 but double check on that. Once you can confirm the board number we can try to work through the schematics
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
