LG top loader tub fills and gets stuck
10 year old WT5270CW LG top loader threw an IE error, no water in tub, with Add Garments lit up. I selected Rinse and Spin and hit Go. Tub filled - like full - which it never does (but didn’t over fill). Stayed in rinse cycle with time remaining decreasing. Never went to Spin. Hubs turned it off/unplugged and checked the drain hose - all clear. Plugged back in and did Spin, tub drained. Tried a new wash cycle - started, tub filled again. Never got past that. Paused the cycle and it manually drained as designed. Any ideas?
Hi @aprilmarti83077
Here's the service manual for the washer that may help.
Run the service mode tests as shown on p.28 of the manual and check if any errors are detected.
If there's a faulty part that needs replacing here's the parts list that is useful.
Search through the list to find the wanted part and when you find it you'll see that the manufacturer's part number for the part is listed with it.
Search online for the part number only to find suppliers that suit you best.
AMart crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 113
