The Huawei P40 Pro is the midrange version of the 2020 P series from Huawei. It was announced on March 26th and released on April 7th. The P 40 Pro offers a 6.58" & 90 Hz OLED screen, a triple rear camera system, 5G and 27W fast wireless reverse charging. Model: ELS-NX9
Dead p40pro+ after disconnecting battery ribbon
I tried to switch off phone which has damaged screen so I simply disconnected battery ribbon from the board. Now, after I reconnected it the phone doesn't switch on. Also after I connected mouse to the phone it doesn't get any power. Normally the LED should light up, even when phone is off. Any help?
Is it normal for battery or mobo to fail in this type of case? I mean just when the ribbon was disconnected when phone was on. I was very delicate. I'm sure I didn't break ribbon cable nor fused anything nor broke the connector/jack.
Hi Kuba, have you tried charging the phone? Some smart phone batteries have circuitry in them to drain the battery if a connection is not detected. You can also try reseating the connector. If not you might want to look into a replacement battery.
Best of luck, BetaTech Labs Repair AU
Kuba Swiezyy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 323
