Why is my Frigidaire electronic oven not heating up
My Frigidaire, model ffef3052tsc, oven and broiler functions are both not working. They quit working at the same time so I feel the cause is the same for both issues. Is there a fuse or something that needs to be replaced? I’m having trouble finding which part I need to replace.
Hi @laurenkbri18833
Is there an error code showing on the oven control panel at all?
Are all the cooktop elements working OK?
If there's no error code (is the clock working?) and the cooktop elements are all OK then looking at the service manual for the stove, there may be a problem with the oven control board (part # 316455400) as the power to both the broil and bake elements are controlled by it.
@jayeff thank you for your response! I don’t see any error codes (as far as I know). The clock and stovetop elements are all still working fine. I’ll definitely look into that part! I appreciate you including the part number
Your oven may not heating due to a tripped circuit breaker, demo mode, blocked vents, a faulty temperature sensor/thermostat, or a failed bake element. Verify power supply, close the oven door fully, check demo mode, inspect elements/sensors, and recalibrate via the control panel before booking service.
Lauren K. Briggs-Cooke crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 94
