Miele Powerline C3 Vacuum Cleaner Starts/Stops by iteself
I have a powerline C3 Miele which was working fine for 5 years. It suddenly has started a strange behaviour, which makes it unusable! WhenI swtich on it cuts out/ switch off after 10 seconds being on, then after few seconds it switches back on for another 10 seconds and it goes on like this (left it for 5 min or so, still does the same thing). I replaced all the filters, checked for any blockage (except inside the motor) and do not know what is is the problem? Anybody had similar issue with their machine??
Our Miele Complete C3 Brilliant started to show a very similar behavior. Will now take it apart to see if can find the issue.
Thanks I hope all goes ok. Do let us know if you get to the bottoms of it.
My Miele Brilliant C3 is having the same issues. I took it to an authorized Miele dealer today to see if it can be repaired and he told me it’s a known issue with this model and has existed for years. He said it’s the most expensive model, but he intentionally doesn’t sell them for this reason. Shame on Miele for continuing to sell it!! Apparently it has something to do with the power in your home, as this model behaves this way in some homes and not others. He said it tends to happen more often in newer homes with newer electrical panels for some reason. He said the panel in their store is old and he doubted we’d be able to replicate the issue in the store because of that. And guess what… He was right! He said every time someone comes in with this issue they can never replicate it in the store. I’m in Chicago by the way.
I would suspect a thermal cutout in the motor because of the timing of the on/off operation. That could because of overheating of the motor or a bad thermal switch. However, I would first check the easy stuff, like a circuit breaker, if there is one, the on/off switch and spade lug connectors.
AliB crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 614
