The HP Elitebook x360 1030 G3 is a 13.3" two-in-one laptop released in 2018. This model name can be found on the underside of the laptop in "Project Name."
My laptop fan makes much noise what should I do
What should I do my laptop fan makes much noise
Hey there,
iFixit features a guide for getting to the fan. If you get to the fan you are going to want to make sure that the the fins of the fan are free of any dust or debris, and can spin freely in their housing. You may also want to apply new thermal paste, as this will help cool your device more efficiently.
Best of luck to you!
crwdns2886500:0Electronics Skillscrwdne2886500:0
crwdns2930805:0crwdne2930805:0
How to Apply Thermal Paste
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
5 - 20 minutes
crwdns2886500:0HP EliteBook x360 1030 G3 Fancrwdne2886500:0
HP EliteBook x360 1030 G3 Fan Replacement
crwdns2937799:0crwdne2937799:0
8 minutes
The fact that it makes noise is a sign that its still working.
First of all, disassemble the machine carefully (make sure you use ESD Mart and / gloves to handle the inside components).
Take out the Motherboard and locate the fan.
Unmount the fan by unscrewing in from the main board and don't forget to unplug the power connector running from the fan to the main board.
Clean the fan with a light brush, you can use a blower as well to remove any dust trapped in the fan.
Use machine oil or lubricant to lubricate the fan (Just a small drop will work).
Make sure no excess oil lingers on the surface of the fan.
Reassemble everything back together carefully and start the machine.
If the noise continue, find a compatible fan and replace it.
Thanks.
Muhammad Shoaib crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 241
