The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Post new valve cover: oil and coolant lost wmilky residue
2003 nissan altima. Due to valve cover gasket leak i replaced entire valve cover 2 days ago. Found oil in 1st spark plug well. Cleaned oil out of 1st well.4 new spark plugs, 4boots and 4coils, new air filter and cabin air filter,oil and oil filter replaced. Please note when hooking up pcv valve when i replaved the valve cover the hose attached to pcv valve was brittle and breaking off near clip. it didn't seem like the connection a hose should have. It was a weak connection in my eyes but my boyfriend thought I was being over critical like I'm often known to be like so it wasn't looked into more. After 24 hour wait.day 1 and 2 more power car doing well never better. Not losing oil. Not smoking. Smooth running. More get up and go.This morning went to get gas day 3. Checked oil its low 1.5 quarts slight milky on stick and under oil cap.coolant in overflow reservoir gone. Car running rough and louder. Please anyone suggestions? I maintain my vehicles treat them well. I can't afford much more but for sure can't afford new vehicle.
Kerrie, milky oil and low coolant likely means a failed head gasket. If this isn't something you're able to diagnose, and you were able to drive the car a mile home. You should be able to top it off with oil and coolant sufficiently to drive to a nearby mechanic. Depending on how bad it is, bring extra coolant and keep an eye on the engine temperature. If the engine gets hotter than normal on the way to the mechanic, pull over and add more coolant, waiting for the engine to cool down again if necessary.
The hose attached to the pcv valve is that called the breather hose? And if the valve cover was replaced but the pcv hose was clogged and reattached what symptoms would the car have? I'm not questioning your answer I'm trying to understand. For last 20 years I have worked In medical field as an MA-C it really bothers me when someone asks me question but agrues my answer that's not what I'm doing here just curious is all. Thanx
@kerriecollinson that would mean that your PCV valve is not doing it's job. That usually manifests itself in an engine that has rough idle and really poor fuel economy due to the engine either running to rich or to lean. You may also experience a fairly rough acceleration of your car, since the air-fuel mixture ratio will be thrown off. Since it is a job of the PCV valve to release some of the pressures that occur during engine operation, a valve that is not working will not allow those gases to leave and thus the internal pressures would increase. That will be evidenced by oil leaks on the engine block and heavy smoke from the exhaust because oil can actually enter the combustion chamber.
The one major issue that you are facing with this, is your statement "its low 1.5 quarts slight milky on stick and under oil cap.coolant in overflow reservoir gone". Your oil and coolant mix and get burned in the combustion chambers. Pull your plugs and take a look at the faces.
It all does sound like either a bad head gasket or a cracked head. I've had both and prefer the head gasket :-) In the old days, we used to check things out a bit different. This is not as easy as it might sound and you can get hurt on this since you may be messing with hot radiator fluid. So if you do this, make absolutely sure that you protect yourself and others at all times and use common sense. Never, ever stand in front of a open radiator or coolant reservoir.
Top off teh coolant and the oil. Once that is done run the engine until it is warm, then stop the engine. Now ( Careful!!!!) remove the radiator cap. Insert a funnel to where the radiator cap normal would be. Now, start the engine (Watch out for hot coolant!!!!). As the coolant circulates you will always notice "some" bubbles" but if you have lots of bubble (yes, you can tell the difference. It looks like you are boiling spaghetti) that means your combustion gases are being pushed into the coolant. That would mean you have a bad head gasket. The funnel is important since it does act as a chimney does for you fireplace. It makes sure that any coolant coming out of this, goes into a certain direction and does not just splatter all over the place.
Again, that is the way we used to do it many moons ago. Just whatever you do, be CAREFUL. If unsure, let somebody more experienced with this, do the diagnostic.
Kerrielea crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 153
