Released in 2013, the IdeaPad U430 Touch, Model #20270, is a streamlined 14" Touchscreen Ultrabook by Lenovo. You can find the Device information and Model number on the bottom of the case.
Why my laptop screen is not open
My laptop is not working .
@divyasingla you are not giving us much to work with here. Don't make us guess! If you are serious about trying to fix your laptop, you need to give us more detailed information.
For now,and from what I "read between the lines" it sounds like your LCD screen is not working. If everything else is working except your screen, connect an external monitor. If that works you know the issue is between your screen, your display cable or your display connector. If an external monitor does not work either, the issue is related to your GPU.
Hi Divya,
Can you elaborate on this issue? Kindly provide the following:
A better description of the issue
images of the faults/issues (if applicable)
Divya Singla crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 119
