Repair information for the LG G7 ThinQ smartphone. Released in June of 2018. Model numbers: G710EAW, G710N, G710EM, G710AWM, G710EMW, G710TM, G710ULM, G710VMX, G710PM, G710VM.
Replaced battery fail after following instruction to let it shut off
I replaced a battery in an LG G7 ThinQ that wasn't holding charge well (age) and would causes spontaneous device shutdown when at lower charge levels and something would cause a power draw spike.
The replacement is the IF303-092-1;
LG G7 ThinQ Battery
After installing the battery, everything appeared to be fine. It came up as 60% charge, and I followed the instruction on the box to "Charge your newly installed battery up to 100% and keep charging it for at least 2 more hours. Then use your device [...]". Charging went fine, and after waiting the device powered up just fine.
The next instruction reads "Then use your device until it shuts off due to low battery." I set up a youtube playlist to play overnight. The phone was shut off in the morning.
However, plugging the charging cable back in only gave the vibration motor buzz and a 'grey' screen, with no indication of it being charged. I left it for several hours, but there was no change. Turning it off (only possible when unplugged) and back on again provides no change. Every once in a while I see what appears to be the beginning of the LG G7 ThinQ's charge indicator circle only for it to go back to a 'grey' screen.
( When I say 'grey' screen - it might well be black, with just the backlight bleed. )
Replacing the iFixit battery with the original battery again, the battery starts charging and the battery charge indicator appears as normal (just takes a very long time to charge).
Swapping it back out for the iFixit battery gets me back to only a 'grey' screen.
Did the instruction to let it drain cause the battery charge to be so low that the device is refusing to charge it?
I'm thinking of starting a replacement / refund procedure, but want to make sure I'm not missing some other step I could take.
( If anyone were to suggest factory reset: though I'd much prefer not to have to perform a factory reset regardless, Vol- + Power also does nothing with the replacement battery in place, whether on charger or not. Have not yet attempted with the original battery in place. )
crwdns2886500:0Replace a BL-T39 model battery compatible with the LG G7 ThinQ smartphone. 3000 mAh. 11.6 Watt Hours (Wh). 3.85 Volts (V).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
LG G7 ThinQ Battery
$24.99
@richardnl if "Replacing the iFixit battery with the original battery again, the battery starts charging" you are saying that your old battery does charge but the ifixit battery does not, then it is a battery issue. Contact iFixit support@ifixit.com and explain to the great staff what is going on. You know they are going to make it right as rain :-)
Thank you for the quick response!
Just making sure I didn't miss some funky "initialize battery" procedure :D
Richard NL crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 174
