Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
Battery not recognised but works unplugged.
Model: A2289 - MacBook Pro 13" Two Thunderbolt Ports 2020
Cycles: 5
Recently replaced battery with an iFixit one.
The system no longer recognises the battery (and coconutBattery shows NaN SoC), and sleeps when unplugged.
Tried SMC reset, PRAM/NVRAM reset, nothing. Assumed another battery failure.
Then tried disabling sleep entirely with the command
sudo pmset disablesleep 1
and now the MacBook runs perfectly fine on battery power, but the system still doesn't recognise the battery.
Has anyone encountered this issue before, or does anyone have suggestions on what else I can try?
Beginning at Step 9 of this guide you can see the battery data cable. Make sure that this was transferred over from the original battery to the replacement battery correctly. If this cable isn't properly installed the system will not recognize the battery properly. If you're certain that the battery data cable and the rest of the battery is installed correctly, then I would operate under the assumption that the battery you installed is faulty. Good luck!
Or the cable is damaged and needs to be replaced MacBook Pro 13" BMU Flex Cable
I just finished a battery replacement on an A1466 MacBook Air and ran into the same problem. Turned out the fix was as easy as opening it back up and reseating the battery connector; on the Air it's a single plug so it's not a one-to-one comparison, but essentially I just hadn't gotten it plugged in fully.
Once the plug was in all the way, everything started working like it should.
dotxyz crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 293
