E1 error appeared?not able to use it
E1 error coming
E1 error coming
I found this:
The E1 error code on your Gourmia air fryer usually indicates a problem with the temperature sensor. This error code is often triggered when the air fryer's temperature sensor fails to detect a temperature reading.
Here are a few troubleshooting steps you can try to resolve the E1 error code on your Gourmia air fryer:
If all of this does not solve it, then a repair is required and the sensor need to be replaced.
Where the temperature probe its located
Hi! Please visit this website for images and further details: https://www.diynot.com/diy/threads/air-f...
The E1 Error Code Is Still Flashing & The A/Fryer Will Not Switch On ??
The bottom pan being in need of a good cleaning seemed to be the reason for the 001 error. I removed the tray to clean it, unplugged it, and replugged it in, the error code was gone.
Brand new air fryer, plugged it up and has the error code and nothing else will come on. Amy suggestions?
crwdns2936753:030crwdne2936753:0 128
crwdns2942667:0crwdne2942667:0 7,646
