The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
Not starting with my hard disk
As I start it or restart it sometimes it not start and after I plug in hard disk it never starts
@gauranshkushwah you re not giving us a whole lot to work with here. Going by what you wrote, this sounds like either a bad hard drive or a bad OS. You will have to check and see if you can get into your computer's BIOS and see if it does recognize the HDD. If so, then it is possible that this is an OS issue and you may have to reinstall it.
Use this 8200 Elite Series Maintenance And Service Guide to fix your computer. It does address hardware, software and troubleshooting steps.
Gauransh kushwah crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 41
