Repair and disassembly information for the AirPods (3rd Generation) wireless earbuds from Apple.
Airpods 3 unable to connect
All of sudden the right airpod are not working. At this moment it is connected normally.
After restore airpods, the right airpod works only when inserted in the case. Further restore after that, the airpods will not connect and constantly flashing white light. What might be the cause and how to repair this?
Can you connect it to anything else and not just your phone
Can you connect other bluetooth devices to your phone?
Maybe try cleaning the charging pins in the case, just incase it's not charging that particular bud. Also unpair your pods from the phone and then turn your phone off and on again and then re-pair the buds in your Bluetooth.
Thanks Pete for your advice. Cleaned my Airpods and restarted my phone, it can detect airpods now but attempt to connect will only get connection failed. White light still constantly flashing.
Is this reparable still?
Try doing a soft reset on your phone. I don't use iPhone but I do know you used to be able to do a soft reset by holding down you power button for about 20.seconds. have alook online how to do a soft reset. Also make sure your phone isn't connected to another Bluetooth device while you are trying to connect to your buds. Phones don't really like connecting to two devices at the same time especially iPhone. I know you could only connect Apple devices years ago to your phone.
Try this
I have done soft reset. Problems still persist- Airpods blinking white light, unable to connect. For now i guess it needs repair by professional, so I have sent it for repair. Thanks for attending to this question.
Hi, have you found any solution to this? I’m facing the same issue, and now when trying to reset AirPods it keeps blinking the amber light instead. I also found some people saying to pair one AirPod at a time, but the case refuses to let that happen.
Syed Elyas crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 381
