Cordless 12-volt power drill/driver released March 25, 2012. This unit is identified by model number M12 2407-20.
Milwaukee drill light stays on no power,
my Milwaukee drill 2407 fully charged battery light stays on, but no power power to the drill itself. Why would then what would be making this happen? Batteries are fully charged
First check if there is corrosion on the battery or actual drill receptors (if it is green) than just pour some pure lemon juice on it, wait for it to disintegrate and wipe away with as close to 99% isopropyl alcohol but not those medical pads because those contain typically only 50%-70%. If that doesn't work check the inside to see if the connection from the battery receptor to the circuit board (CB) is fully connected, CB to drill bit. Check the receptor from the drill trigger to the CB, or test if the trigger sets off the receptor at all (see if there is contact or any other way that the trigger would set it off. If none of these check the drill motor connections, replace the motor. If the motor is replaced and everything works then it's a CB problem.
steven f cordova crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 536
