Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
Why doesn’t Bluetooth work anymore
I reinstall windows because I accidentally installed a virus and when I reinstalled windows Bluetooth just doesn’t work anymore when I try to connect it says this device doesn’t have Bluetooth even though it does
@braedenrader since it stopped working after you reinstalled Windows, I suggest that you get the proper driver. Check on the Dell site for the latest bluetooth driver.
Dell doesn’t have any drivers for it
Hi @braedenrader
Is the Bluetooth adapter entry being shown in Device Manager?
To get to Device Manager in Win10/11 press the Win Key and the x key (both together) and click on the Device manager link in the menu box that opens.
Once in Device Manager, Bluetooth should be listed as a category, the same as Network, Display Adapters, Monitors etc. If it isn't listed check if there's a category listed as Other Devices and if so click on the category to expand the list and check if there's an entry for either an Intel AC7265 or Dell 1560 Bluetooth adapter (XPS 13 9343) or Intel-Wireless-AX200-AX201-9260-9560-9462-8265-8260-7265-3165 (XPS 13 9350) listed .
If no entry for either is shown, in Device manager, click on View → Show hidden device and check if the Bluetooth adapter is shown anywhere at all in Device Manager.
If you do find a Bluetooth entry in any of the above places in Device Manager:
If there's a yellow exclamation mark next to the Bluetooth entry, here's a link to the Dell XPS 13 9343 Win10 Bluetooth drivers (or Dell XPS 13 9350 Win10 Bluetooth drivers). Select Additional Resources → Find Drivers → Download type → Driver to find the applicable Bluetooth driver download entry.
If there is a red cross next to the Bluetooth entry, right click on the entry and click on Enable and follow the prompts and check if it works OK.
FYI Dell doesn't have Win11 drivers as your model (either model) is not supported by Dell for Win11, but the Win10 drivers should work or usually Win11 generic drivers usually work as well.
I had the same problem. Troubleshooting told me that Bluetooth was not fitted. Going to 'Services', and restarting the three Bluetooth items, worked once, but not for long.
I then decided to fit a new SSD, and opened up the laptop, to check what was fitted. I removed the existing SSD, cleaned the heat sink and card, and replaced it. Bluetooth re-appeared, and has been working perfectly over the past four days. Also, I have experienced the fans 'chattering', creating an eerie sound, like dogs barking in the distance. I no longer have that irritation, and the computer is running slightly cooler.
Braeden Rader crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 609
