Repair and disassembly information for Google's Pixel 8 smartphone, released in October 2023. Identified by model number GKWS6 and G9BQD.
do I need to replace the adhesive?
If I open it up do I need to replace the adhesive?
Short answer. Yes.
Longer answer. Depending on where you open it up you may damage the adhesive and it will be safer to replace it than not doing it. Replacing it will also ensure liquid resistance is kept.
I would recommend replacing the adhesive after you open the device up. The adhesive helps ensure dirt, dust, and water doesn't get into the device. Not replacing the adhesive could result in moisture damage, which would end up costing you far more than the relatively small investment.
Google Pixel 8 Screen Adhesive - Genuine
crwdns2886500:0This custom cut adhesive film secures the display panel to the frame of a Google Pixel 8 smartphone.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$3.99
Grayden Hormes crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 99
