This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
bro's ds lite has a white bottom screen, HELP
So my friend sent me his broken hinge ds and told me:
-Help me fix the white bottom screen and the broken hinge please, i need to sell it working.
And i replaced the housing for him, now just have this annoying white screen:
I tried replacing the bottom screen: still there.
Diagnosis on the old screen: No Rips And Tears, works perfectly fine on another ds lite.
the touch screen replacement: still waiting for the package
Help Please, Thank You
Update (03/27/24)
update:
for Mango:
bottom of the board:
the other side:
the top screen zip connecter:
the bottom screen zip connecter:
Hey. Have the same issue. Did you find the solution?
So if it's not the screen, the next thing to check is the bottom screen ZIF connector. Look it over carefully and make sure there aren't any bent/broken pins or cracked solder joints. It also wouldn't hurt to clean both the cable and connector with a toothbrush and isopropyl alcohol.
While you've got it open, check the rest of the board for any visible damage. If you find anything, you can add a pic and we'll go from there
crwdns2944067:011crwdne2944067:0:
cracking it open, wait a bot
top screen ZIF connector? take a look at my newest update
@trananhkhoakyle Bottom screen, my bad.
its ok i sent both
can you check the connecters from the pic?, it looks fine to me
crwdns2934275:06crwdne2934275:0
Tran Anh Khoa (Kyle) crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 641
