Replaced antenna and no longer turns on
I have amateurly replaced my R Joycon antenna with one I believe to be an older model of, and I want to know if I might have short circuited the controller by prodding around with metal tools.(im new to this site)
crwdns2944067:011crwdne2944067:0
Have you checked all connections in the controller? Might be a loose connection too
@markusnorstroem So i have to make sure they are in-in? like slight looseness might be it?
@kingrss I'd at least start there as I've had similar issues with other nintendo consoles and fixed it by checking for loose connections
@markusnorstroem Ok thank you
@markusnorstroem Also I recently discovered that if I connect it to the console and press the home button twice it works (but if I disconnect it nothing)
crwdns2934275:06crwdne2934275:0
Go around with a voltage meter and see if there is any shorts in the circuit and make sure everything is plugged in.
King RSS crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 90
