The Cuisinart DCC-1200 can be identified as Brew Central Coffeemaker apart of the DCC-1200 Series released in 2015.
coffee does not flow into the carafe
brewed coffee stays in the filter basket and does not flow into the carafe
@ccoffee can you verify that your coffeemaker is a Cuisinart DCC-1200?
it is a dcc3200 cuisinart coffee maker.
@ccoffee let's see if the ifixit coffeemaker Guru @vauweh has any ideas on this new machine.
I don't know this devices, I can only give some general advices:
I wish you success!
Hello ccoffee! It may be because your coffee maker is clogged, and is unable to send any coffee into the pot. You can use a piece of wire to clean, or you can, if possible, wash it out. I hope this fixed your problem! - Gilchrist Dean
thanks but no not the problem coffee maker is brand new and i have washed it out after each use only 3 times used
ccoffee crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 104
