Released in January of 2021. Identified by model numbers SM-G996B, SM-G996B/DS, SM-G996U, SM-G996U1, SM-G996W, SM-G996N and SM-G9960.
Water droplet in camera lens.
Currently, my phone has camera has water droplets at the lens. What should I do? Do I need to bring it into a repair shop or is there something else I can do?
The problem will likely persist even after a long while of drying due to the fact that the Galaxy S21+ should have a water resistance rating of IP68. While the IP68 seal may have been compromised at a small point (otherwise there would not be any water ingress), it will take a very long time for all of the moisture to evacuate your device naturally from that tiny, localized break in the seal.
I would recommend following this procedure to take the camera out. You can then let it dry for a couple of hours or very carefully use a piece of paper to soak up the droplet, trying to limit the number of fingerprints and amount of dust that may fall onto the surface of the components.
Gabriel Yong crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 438
