Mine no longer play games only dvd and blueray
@edgardopaz that is caused by either a dirty or a failed laser. You can try and get those commercially available lens cleaners and run that a couple of times. If that does not work, you could try and replace the laser assembly. Not sure if you can see this guide (it's in process Xbox 360 S Laser Lens Replacement ) The other thing you can try is a pot adjustment for your laser. Worst case scenario with that is that you may burn your laser out. See if this will work for you XBOX 360 POT CALIBRATION
crwdns2942667:0crwdne2942667:0 47
