How to change the battery?
Hi,
i Have this model HP Laptop - 14s-fq0010nj
i wanted to replace the battery when i flipped the laptop and removed from the back case all the screws (as i think )
i were not able to remove the back case yet - its like its stuck or there a something inside that holds that case - now im unable to remove the back case
also - i have no idea how the battery look inside - can i just replace the battery if i removed the back case
thank you
wajde
@wajdefadool use this manual HP 14s Service Manual to work on your computer. Yes, besides the screws the bottom cover appears to also snap in. Check page 32 of the manual
Well I will suggest you to check out the following video it might help you in fixing the issue:
https://www.youtube.com/watch?v=vrX_vghe...
Wajde Fadool crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 235
