Released on August 22, 2022, the Z Flip 4 is one of the folding phones Samsung has made over the past few years.
Why my phone keeps shutting down when flipped
My phone is suddenly shutting down, with power down when the screen is flipped, it is shutting down on its own completely. I tried to turn it on by plugging in charge, it is making no sense
I am not terribly familiar with the inner workings of the Samsung Z Flip family, but I suspect that a wire, perhaps a battery ribbon, may have worn out over time and cycles of flipping. Moving parts will always wear out, and after enough cycles, components that are subjected to slight tension or bending forces will eventually break.
When you flip it, perhaps this malfunctioning wire is pulled out of position and there is no contact being made, causing it to lose power completely, shutting it off. It could also be the opposite– Some exposed wire could be shorting with another, causing it to restart.
I would take the phone apart and inspect the state of the cabling inside of it, looking for any obviously worn ribbons or wires.
you need to replace the hinge ribbon cable
Shaily Dev crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 3,421
