Oppo A37 A37fw 16GB comes with 2GB of RAM. The Oppo A37 runs Android 5.1 and is powered by a 2630 mAh non-removable (as told by Oppo ;-) battery. First released in April,2017.
In my oppo phone not run updated youtube
This phone isn't compatible with this app written when I open youtube app
crwdns2889612:0crwdne2889612:0 9
crwdns2944067:05crwdne2944067:0
Problems Update
YouTube not update in oppo a37f
YouTube nhi chalra
how to fix coloros recovery
Mere phone m youTube download nahi ho rha hai
You should make use of the browser version of youtube. It allows for a slightly lower level alternative.
Hi @ayushmanraj,
Have you tried updating the phone's system software in the phone, you didn't say?
Go to Settings → Software update. Ensure that the phone is online when trying this.
If the phone's software is the latest version, then unfortunately you may have to revert back to the previous YouTube app that did work.
i have same problem, then i realize it's cause by full memory and storage.
apps need storage to save it, but need much memory to run.
okay the reason behind the incompatibility is an outdated Android version. The Oppo A37 runs on Android 5.1 which is quite old. with that the newer versions of YouTube app may no longer support this version. possible solutions to the problem try this;
  1. install an older version of YouTube app via third party APK sites
  2. give a try to YouTube Go which is considered a lighter version of the app
  3. lastly use YouTube in a browser instead of an installed app
Ayushman Raj crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 1,124
