Repair and disassembly information for the fourth-gen iPad Pro 12.9". Announced and released in March of 2020. Model A2229.
iPad Pro 12.9, USB Data Transfer Failure
iPad Pro, USB Data Transfer Failure
This is the iPad Pro 12.9-inch 4th generation model.
The connection to the computer via USB-C port is not working. My computer doesn't detect the ipad at all. (The same goes for ipad recovery mode.)
Currently, iPad is not a matter of computer trust because it has completed a factory reset.
I've also replaced the cable, but it's the same as the A to C cable or the C to C cable.
The symptoms are the same when I try on another computer (both Windows Desktop/laptop and macbook air M1)
Eventually, I disassembled the iPad and replaced the dock flex cable, but the symptoms didn't change. And I checked the logic board with a multimeter, but I couldn't check the short circuit/abnormal heat in components such as capacitors.(I have not yet checked the metal shielded part.)
Surprisingly, all other features are normal. There is no abnormal power off / panic full crash and the battery works well.
1. PD Charge - OK. Charging speed is also normal.
2. External Storage Connection - OK
3. External Monitor Mirrors - OK
4. USB-C Hub Connection - OK
I don't know the cause...Is it a failure of the USB IC?
I'm having the same kind of problem with my USB connects some things but not others now. Apple sucks.
wellbinnn crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 361
