Why dose my 2006 Camry not starting
I had to replace my timming belt and my alternator but now am getting lights and evrything but my car wont turn over and whrn do try there is no noise at all coming from motor
Paul, Are you still having this problem? If so, recommend going back to the basics and checking fuel, battery, starter, etc. If no crank, can you still hear the fuel pump turn on when turning the key to ACC? If not, check the fuel pump fuse. If so, check the battery. If all of that is good, check the starter, including if power is going to the starter.
Are the lights on then probably not batt........if just click no vroom the starter and if it dies every time you turn it off your alternator
.........gl
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 24
Are you sure you didn't mess up with the timing when you changed your belt?
crwdns2934271:0crwdnd2934271:0 Vertinhol crwdne2934271:0
yes just took the old one off and put new one straight on
crwdns2934271:0crwdnd2934271:0 Paul Nicholson crwdne2934271:0
