front camera not working, in diagnostic test it fails
at first it worked with message showing 1431111 like but i haven't memorized exact number, with some of camera features failure messege.
Now camera not working at all. i am from pakistan and there is no outlet of motorola in pakistan, as it is not launched here, i am using refurbished motorola set.
@mudasirhussain if the camera fails in diagnostics, replacing it would be a good start. Since iFixit does not yet have a guide for that, use something like this video to work on it. Cameras are readily available at many online stores.
Dear, my camera issue is not hardware related. Its software or application fault
@mudasirhussain How did you come by that conclusion? The diagnostic tests are not there to test software; they verify the hardware is functioning correctly. If a component fails a diagnostic test, then that component has failed, not the software that accesses or controls that device.
I would suggest you follow @oldturkey03's advice and start by replacing the camera, but you can always satisfy yourself that it's not a software problem by wiping the phone back to factory settings. If it works there, then and only then you can say it's a software problem; otherwise in the opinion of at least a couple of guys with decades of experience, it's the hardware.
Mudasir Hussain crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 179
