Blue shadow for first 5-10 minutes TV is on
After turning on:
After 5 minutes:
My Samsung LCD TV has an issue where I see blue shadows, especially off of black images, for the first 5-10 minutes the TV is on. It goes away after that and the TV is fine until the next time it powers on after it's off for a while (if I turn it off/on momentarily, the picture is still good). Can anyone advise on what this might be?
(One small callout- the "check signal cable" message is not an issue - I didn't have an input selected when turning on the TV. The only issue I'm facing is that blue coloring in the first image)
@briang3 sinc this is only while the TV is cold, that make this either a cold solder joint error or a bad component. Check the main board for any component that may look odd, darkend, charred etc. While you inspect our board, you also want to note the color of the solder joints. They are supposed to look shiny silver. If they are matte and lead colored, do a quick reflow with a soldering iron etc.
If you have your back cover already removed, take a couple of pictures of all of your boards with your Question. that way we can see hat you see and hopefully help you further. Adding images to an existing question
Thank you- I will examine it and confirm this works!
Brian crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 150
