The slider broke, superglue is not fixing it.
I have been trying to stick this with superglue but it keeps falling apart, even after waiting 10-20 minutes for it to cure. Can someone suggest alternative methods to stick this? The headphones work fine its just the slider thats broken.
crwdns2889612:0crwdne2889612:0 10
Yes same issue
Hi @rajveerenamadar
Try using an epoxy type adhesive (example only) and check if that fixes it.
https://youtu.be/WlPvijubuQg?si=CtPWd-sL...
Watch this it helpful, I did it
thnx bro it helped me
Get something like a ATM card. Cut it. Glue it over the broken part and the opposite side.
Hey, Buddy,
I have the same Headphones and faced the same issue at the same place,
what I did was, I made two creases parallel to each other that would fit a 1.5" metal wire.
I placed the metal wire in the crease, half of the wire on the head rest part and the other half on the ear rest part, so that it would hold together, then I used superglue on it,
normal super glue does not work, even in my case it didn't, but when you put baking soda on the superglue before it dries, it will make a strong bond and will last longer.
so try the trick with baking soda on the superglue.
Hope this helps you with your Issue. Thank you!
Ise kese chip Kay
Saad crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 154
crwdns2942667:0crwdne2942667:0 1,700
