2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Correct battery replacement for A1398 EMC 2745
Is Item # IF117-047-6 correct for the above mentioned laptop? I ordered and received this, but now I see the guide says "early 2013" but i think my laptop (EMC 2745) is late 2013. I thought I ordered the right one, but does anyone know?
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
crwdns2886500:0Replace a 8680 mAh battery compatible with MacBook Pro 15" Retina Mid 2012 to Early 2013 A1398 model laptops. 11.26 Volts (V). 99 Wh (Watt Hours). Battery model A1417.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$79.99
The EMC number 2745 is a Late 2013 15” MacBook Pro (DG) is that your system? Double check by clicking on the About this Mac.
I would think the EMC number etched on the bottom wouldn't lie. I don't know how I ordered the wrong battery, but luckily I double checked the procure and noticed the incorrect date range.
@jacob14905 - So you then have the Late 2013 model not the Early 2013 correct?
yes, thanks for your help on this!
@jacob14905 - Just curious how it ended! Don't forget to score and accept the answer - Thanks!
The correct battery for the late 2013 system is this one MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery and the guide MacBook Pro 15" Retina Display Late 2013 Battery Replacement
crwdns2886500:0Replace a 8700 mAh battery compatible with MacBook Pro 15" Retina (Late 2013/Mid 2014). 98 Watt Hours (Wh), 11.26 Volts (V).crwdne2886500:0
$89.99
jacob crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 220
