The Google Pixel 2 is Google's second flagship phone, released on October 17, 2017. The phone features a 5-inch AMOLED display and comes with 64 or 128 GB storage options. It is available in three colors: Just Black, Clearly White, and Kinda Blue.
Forgot to reinstall the screen cable tiedown
I replaced the battery in my Pixel 2, which mostly went just fine. It turned on afterwards and the screen works fine. However, I realized after I had reattached the screen and gotten it fully glued down that I had forgotten to reattach the small piece of metal the covers and holds down the screen cable attach point. Is this something that I should take my phone apart again to fix, or will it be fine to have left it out?
Hi Zach,
As a fellow Pixel owner, I've had and worked on the 2 XL, 4 and 6 Pro models, so I've been around them for a while now.
My advice would be to set your little metal cover aside somewhere safe and don't worry about it for now. Its only purpose is to secure the display connector so it can't get jarred loose, so your phone will work 100% correctly without it. The risk you run is that it's possible that one day down the road you may drop the phone or bang it against something and knock the plug loose. It's very unlikely but it could theoretically happen. If something like that were to occur and the screen goes black, then the first thing you'll want to do is open it up and make sure the plug is still in place. At that point you could put the cover back on.
The screen itself is very delicate and you run the risk of breaking it by trying to open it back up, so I wouldn't do it unless there was a compelling reason to. In my opinion, putting that cover back on isn't worth it.
Zach crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 320
