Hi Frank,
Check the operation of the flash; can you turn on the flashlight? If not, that would point toward the flex cable that has the power button and the flash on it. It's right next to the display connectors you would have had to unplug when you took off the display, and would be easy to dislodge while you're disconnecting the digitizer and LCD. Here's the connector I'm referring to.
It's shown on Step 40 of the iPhone 6s Plus Power Button Cable Assembly Replacement guide.
That would be my bet. You'll have to open up the phone again and make sure to reseat that connector. Test before you button it all back up again; if you're still having issues unplug it and check both sides for any bent or broken pins; those FPC connectors can get damaged if you screw down the retaining bracket when they're not plugged in correctly. Sometimes you can straighten out bent pins with fine tip tweezers.
Go ahead and check the connector then come on back and let us know what you found. Hopefully it'll be a simple fix.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
3
