8 inch tablet released in July of 2019. Came as a 32GB or 64GB model. The display is a TFT LCD with a resolution of 800 x 1280 pixels. Main Camera is a 8 MP camera and the selfie cam is a 2MP cam. The versions are: SM-T290 (Wi-Fi); SM-T295 (LTE)
Numerous power cables and chargers will not charge my tablet.
My tablet has been charging and running just fine. Just all of a sudden from numerous cords and chargers it will not take a charge. Scanned , reset all but back to factory default. now down to 11%. Turned off and will not show a charge. Cleaned charging port with electrical cleaner and alcohol. All other chargers and cords that work on similar devices will not show a charge. Did the battery just suddenly go bad/?
Hi Nick,
In most cases even if the battery is bad the device will usually run when plugged into power, a charger in this case. The fact that it isn't coming on would tend to indicate that no power is getting into the device rather than saying that the battery isn't holding power.
You've already done the first part of figuring out this problem; that of trying different chargers and cables to eliminate the power source as the problem, so I would tend to suspect the charging port may have a bad connection to the daughter card it sits on; that's the most common kind of failure with this sort of problem. If it was mine I would replace that daughter card first then reevaluate and see where you are.
Fortunately on your tablet it's actually a pretty easy job to replace that circuit board. I didn't find any written iFixit-style guides, but there's a pretty good YouTube video showing you exactly what you need to do.
Samsung Galaxy Tab A 8.0 2019 T290 T295 Charging Port Replacement - YouTube
Nick Savener crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 292
