Repair guides and disassembly information for the 16-inch MacBook Pro released in January of 2023, featuring Apple-designed M2 Pro and M2 Max SoCs.
MacBook M2 keyboard remplacement
Hello, I need to change a few keys on a MacBook Pro M2 model 2780 keyboard. I found replacement keys from sellers, supposedly compatible with the M1 2485 & M2 2780, could you confirm to me that the keys of the 2485 are indeed the same as those of the 2780?
Do the keyboard keys on the M2 2780 unclip as easily as on the M1 Macbook Pros?
Do both keyboards use the same clipping system?
Bonjour,
j'ai besoin de changer quelques touches sur un clavier de MacBook Pro M2 model 2780. J'ai j'ai trouvé des touches de remplacements chez des vendeurs, des touches compatibles avec les M1 2485 & M2 2780, pourriez-vous me confirmer que les touches du 2485 sont bien les mêmes que celles du 2780?
Si oui, est-ce que les touches du clavier du M2 2780 se déclipsent aussi facilement que sur les Macbook Pro M1 ?
Les deux claviers utilisent-ils le même système de clipsage ?
Given how new the system is you likely can get Apple to replace the key caps even for free if you have access to an Apple Store. Many authorized dealers will do it for a bench fee as they have the parts or can get them in a few days.
Sadly, I don’t know what Apple has done with the new M Series keyboards. I haven’t had the need to dig into it and the few customers I’ve had got the key cap replaced for free here in the states at an Apple Store.
I can confirm that the keyboards are the same on both A2485 and A2780; I have installed A2485 keyboard onto A2780 with no problem.
If the seller states that they are compatible with A2780, I would trust it.
Laurent Thuaud crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 1,174
