Hi @tygresfury
Try a full power refresh and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop (if connected).
b). Disconnect the main battery from the laptop.
c). Disconnect the RTC coin cell battery from the motherboard.
Here’s the maintenance and service guide for the laptop. Go to p.40 & p.55 to view the procedure to remove the main battery and the RTC battery, respectively.
When the RTC battery is removed, measure its voltage. If it is <2.5V DC or >5 years old, replace it. Search online for 665733-001 to find suppliers that suit you best.
d). Press and hold the laptop’s Power On button for a full 30 seconds and then release it.
e.) Reconnect the RTC coin cell battery, reconnect the main battery, re-assemble the laptop, connect the charger to the laptop and try to start it.
If it starts OK, there may be a message about the date and time being incorrect. This is normal as the above procedure has reset the BIOS back to its factory defaults. Once the date and time have been adjusted, the message won't appear the next time the laptop is started. Any user definable BIOS settings that have been altered by you to suit your particular operating requirements will need to be changed back also.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
Screening shows preparing automatic repair
crwdns2934271:0crwdnd2934271:0 Farhan crwdne2934271:0
I have an Hp Elite Book 840 G3. Has been off for about 5months since I have not been using it. I have tried to charge it and turn it on but it doesn't. It just lights the keyboard buttons on and off and keeps like that. Any help?
crwdns2934271:0crwdnd2934271:0 Baram Nax crwdne2934271:0
