SanDisk media player with Rhapsody. Physically identical to the e260. Model number SDMX4-4096-A70.
Faulty Battery or Faulty Connector?
Good evening,
I’ve recently dug up my old Sandisk mp3 and thought I’d try to use it again. I ended up using a known-good generic 3rd party Apple 30-pin connector to plug it in into the wall socket. I tried turning it on a few times to see if it would run on power but the same message would appear.
“Battery is too low. System shutdown.”
I even let it alone for 30 minutes but there wouldn’t be any battery indicator or changes on the screen, same message always ends up popping up.
Another thing I ended up finding out was that whenever I wiggled around the cable the ring light-thing would turn on for a very quick second but then turn off. i checked the connector itself and it didn’t seem to have any external damage to the prongs or the connector itself.
Not sure if it has to do with a battery replacement but, I wanna double check myself and see if my suspicions are correct.
Any information or tips are appreciated.
Boy, that's a tricky one. Obviously it's complaining, probably accurately, that the battery doesn't have enough charge to work. I think you've done a good job covering the first step, that of making sure your power source is good by using a known good cable and charger.
That leaves us with the two parts you're suspecting, the charging port and the battery. To be honest due to the reaction of the port to your wiggling, it sounds like the reason the battery isn't getting charged is that you haven't got a good connection between the charging port and the plug on the cable.
However, I'm going to suggest trying a new battery first for the simple reason that it's easy to replace the battery and really really hard to replace the charging port. I'd want to 100% eliminate the possibility that the problem is with the battery before I even considered trying to replace that charging port.
There are a couple of issues with replacing that port. First, of course, is the difficulty in soldering a 30 pin connector. That's a lot of pins to get soldered on correctly, so there's a lot of room to make a mistake unless you're fairly experienced at soldering. The second part of that issue is that of locating a replacement port; I did a somewhat cursory search and came up with bupkis, nada, nothing.
So yeah, I'd say your next step should be to swap out that battery. If that doesn't work there's a small possibility a different charging cord may work better; you could try and locate one that's being sold specifically for your Sansa as a suggestion.
Try those out then come on back and let us know what you found. If it's still not working we'll see if we can figure out where to get a replacement charging port for your device and how to replace it.
Hi there, apoligies for the rather long wait for your answer.
I did some reasearch today after realizing a few things and found that it may have to do with the cable, well, equally with the battery but, on some forums I found on Sandisk's offical website, it seemed I wasn't the only one who was curious to see if a standard iPod 30 pin connector would work with the unit.
From what some users have said, while the connector itself remains the same, it seems the Sansa unit has some connecting points or specific pins that it needs to use in order for it to charge and/or sync up properly.
Heres the provided forum here: https://forums.sandisk.com/t/adapter-cab...
In any case, I went ahead and ordered a battery for my unit to see if that fixes one issue. More than likely will have to search for a cable somewhere but, I beleive the batteries the high priority issue.
Thank you for your response for this nische product in any case, wish you the best!
Hillarous update, ended up finding the cable I needed through a junk drawer, and when connected it to power, the unit just powered right up with no issue, even going as far as to charge the battery.
Though, considering its age, I'll more than likely still replace it. Thank you again for your assistance!
@nameunlisted Awesome, I'm glad to hear you found the solution. And thanks for coming back and letting us know what you discovered - it is quite likely that someone else down the road will come along with the same problem and your response could well give them the answer they're looking for.
nameunlisted crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 179
