A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
Display is not working after SSD Upgrade
Hello. So I just upgraded my iMac (21.5 4K 2019) with an SSD
How can I tell if either display cables on the iMac LCD is bad? My iMac display won't turn on after doing the SSD upgrade and reconnecting the LCD to the logic board. I'm using an external display and everything is working except for the iMac display. If I go to settings - display the built-in display is recognize. But again nothing shows up in the screen - not even the apple logo when turning it on.
Also the Facetime Camera is working.
Hi @carlossosa72884
I'm not sure of the problem here since you did an upgrade but you probably damaged the display or it's cables while you upgraded the SSD, Since your computer recognizes the built in display the wires should be working so the display may have to get replaced.
Let me know of any developments
Hi @ihave0idea.
Thanks for the quick Reply.
So I tried disconnecting the black power cable. Not the eDP cable but the other one, to see if anything change, and I got the same behaviour. No display, Display shows up in Settings and Facetime Camera works.
Also I checked the LED Lights on the Logic board and 4/5 turns on. I believe the 5th light (the one that does not turn on) is the display backlight/power.
iMac won't boot, black screen and no external display
So not sure if that's the damaged cable.
HI @carlossosa72884
Thanks for replying, Like i said before. You may have to replace the LCD panel on the mac
Carlos Sosa crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 146
