Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Torn black film on logic board
While trying to remove the battery to replace it, I tore the black film that's on the logic board, leaving an approx 1 inch tear exposing some kind of silver cover just underneath. I just wanted to know if this is something that would require a replacement or if it should be fine as is.
I did some reading around and found that tears to the film on the wireless charging coil underneath the battery weren't much of an issue, and I'm assuming that the film on the logic board is the same kind of graphite shielding as on the wireless charging coil.
I have some electrical tape on standby if that can be used to cover the tear. Any help is greatly appreciated!
The black tape (called Graphite Tape) is for heat transfer and acts like a heat dissipator. The silver metal shields are EMI shields.
Should be fine without it, but if you're worried you can order the tape online.
its just like a thermal tape it will be fine without it
Can anyone tell me what the little black square thing that looks like black electrical tape, that is on one of the metal pads at the very top of the inside of the iPhone 8 is and what it’s purpose is? I accidentally took it off when changing the camera and earpiece units.
Same here if i replace with electrical tape am I ok
Tyler Drake crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 572
