Apple's top-of-the-line smartphone for 2021. Released September 24th, the iPhone 13 Pro Max sports a 6.7" ProMotion OLED display, a new triple rear camera system, and 5G connectivity. Successor to the iPhone 12 Pro Max.
Earpiece speaker not working iPhone 13 Pro Max
Hi, I just replaced the earpiece speaker for my iPhone 13 Pro Max and the earpiece is still not working, could it be a dodgy connector where the gold pins touch?
Should I buy this to fix it?
Thanks
Hi Terence,
Well, it seems to me you're on the right track; the earpiece speaker would be my first approach as well. The contacts for the speaker are on an assembly called the WiFi Antenna; those contacts run through that flex cable to the motherboard so it's definitely worth trying to replace that.
Of course, if it still doesn't work after that then you're probably looking at a motherboard/audio chip problem that would require specialized expertise to fix, but I'd definitely replace the WiFi antenna first. Unfortunately iFixit doesn't have a guide for that, but the Spanish site Nadie Me Llama Gallina has just what you need.
Manuals / Apple iPhone 13 Pro Max / WiFi antenna
You can buy the part itself right here on iFixit, and of course don't forget another sheet of screen adhesive so you can put it back together again.
iPhone 13 Pro Max Wi-Fi Antenna
I'd say give that a try then come on back and let us know what you found.
crwdns2886500:0Replace a Wi-Fi antenna compatible with an iPhone 13 Pro Max smartphone models A2342, A2410, A2411, or A2412. Fix unreliable connectivity to Wi-Fi devices.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$7.99
Terence Liu crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 717
