The Apple ImageWriter II is a dot-matrix printer released by Apple in 1985. It accepts both line feed and regular 8.5 by 11 inch paper.
Apple ImageWriter II won't print from Macintosh Plus
Hello! My Apple ImageWriter, even when connected to my Macintosh Plus through the correct selected ports, will not print. After I ran the self-demonstration, it proved that there is not a mechanical failure, and it will print. Whenever I select print in a document, it says it is printing, but nothing happens. Eventually, the pop-up goes away.
You need to open the printer selector dialog box to reset the port. It’s likely the CMOS battery needs replacing as the setting got lost.
I have checked all settings, and they appear to be OK. I think it might the cable I was using that I bought. It might not have had the right pinout.
@wmf10 - this is a different cable than before?
crwdns2947515:0crwdne2947515:0
_nec6678 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 69
